I am selling a custom-made Patch Snake/Patch Panel Setup, as I have decided to go another route - that is, the Appsys ADAT Extenders.
All hardware is new and is worth approximately $1000.00.
This setup allows you to have 8 channels IN, 4 channels OUT, and 1 DMX channel
Consists of the following:
2 - ART Pro Audio 16-Channel XLR Balanced Patch Bay
1 - 13 channel custom-made patch cable with 8 Sends, 4 Returns and 1 DMX at 50'
Details: Patch Panels
The P16's have been reconfigured to match up with the patch cable as shown in the attached images.
One panel is designated as STAGE and the other as FOH, but can be located wherever you desire.
The panels are new, just with the mods.
[ATTACH]2448[/ATTACH]
For information on the patch panel, see here: http://artproaudio.com/patchbays/product/p16/
* IMAGE A: P16's in factory configuration. Note: There are two of these.
* IMAGE B: FOH, Showing a comparison between the stock configuration and the custom configuration
* IMAGE C: STAGE, Showing a comparison between the stock configuration and the custom configuration
[ATTACH]2449[/ATTACH]
[ATTACH]2450[/ATTACH]
Details: Patch Cable
The cable has been custom-wrapped in Tec Flex and has been professionally made by BRTB.
There are 8 Sends using high-grade XLR cable.
There are 4 Returns using high-grade XLR cable.
There is 1 DMX-grade cable.
The patch cable is new and therefore, has never been used.
Note: Not exactly as shown in image.
I am open to reasonable offers or trade.
Focusrite Saffire Pro 40 - SOLD!
Mint condition, all docs, box, etc.
Price $400.00 CND.
For $10.00, I will provide an approved FireWire card and cable as well.
Patch Panel, Cable and Focusrite Pro 40
Re: Patch Panel, Cable and Focusrite Pro 40
Did you go in and resolder the P16's to change the male female? That's pretty swift!
Dale,
Yes, that is exactly what was done!
Other than a bit time consuming, it was actually quite easy to do.
