Behringer x 32 + SAC
andrew b
Post by andrew b »
can Behringer x 32 be used with SAC as converters or controllers? I find it more convenient to work in SAC)
Ruben VS
Re: Behringer x 32 + SAC
Post by Ruben VS »
andrew b wrote:can Behringer x 32 be used with SAC as converters or controllers? I find it more convenient to work in SAC)
I understand you are referring to using the Behringer S32 stage box with SAC.
There is a small problem and that is that you need an AES50 interface that is capable of generating WordClock in this protocol.
There is an option that would be to use the S16 boxes that do generate the Word Clock and you could use them with the KlarkTeknik AES50 Interface.
My Setup SAC:
interface - digigramLX646
preamps - Yamaha Ad8hr
Outs - Yamaha DME80-es
protocol audio - Ethersound
I control gain remote ;);
andrew b
Post by andrew b »
Ruben VS wrote:I understand you are referring to using the Behringer S32 stage box with SAC.
not so . x32 full size console no stagebox
Ruben VS
Post by Ruben VS »
andrew b wrote:not so . x32 full size console no stagebox
If the mixer has a USB card, yes, you could. But the mixer wouldn't be useful for anything...only for controlling the channel gain. I don't know, I don't see it as a fast workflow.
My Setup SAC:
andrew b
Post by andrew b »
Ruben VS wrote:If the mixer has a USB card, yes, you could. But the mixer wouldn't be useful for anything...only for controlling the channel gain. I don't know, I don't see it as a fast workflow.
https://musicmarket.by/product/karta-ra ... ger-x-adat
Ruben VS
Post by Ruben VS »
If you put this card in the mixer, you can't have the USB card. Therefore, you won't have the tracks in SAC via ASIO. Unless you have an Adatta interface on your PC.
My Setup SAC:
