PreSonus FaderPort 16
andrew b
Post by andrew b »
PreSonus FaderPort 16 + SAC will they work?
Been thanked: 11 times
Re: PreSonus FaderPort 16
Try using the Mackie MCU mode with the SAC Mackie template.
andrew b
Post by andrew b »
Bob L wrote:Try using the Mackie MCU mode with the SAC Mackie template.
I don't have PreSonus controllers yet, so I'd like to know for sure if they are going to work with SAC...
So you can't say for sure, right?
cgrafx
Been thanked: 7 times
Post by cgrafx »
andrew b wrote:I don't have PreSonus controllers yet, so I'd like to know for sure if they are going to work with SAC...
Hey Andrew,
there is no way to know for sure how much functionality will work without actually having the hardware to test.
If you are purchasing new, then just make sure to buy from a location with a known good return policy. Then you can try and see for yourself.
Ruben VS
Post by Ruben VS »
I recently asked the same question, and someone told me it was. I ended up not buying the PreSonus and bought two extenders for my Mackie MCU. But I remember someone telling me they'd tried it and it worked.
My Setup SAC:
interface - digigramLX646
preamps - Yamaha Ad8hr
Outs - Yamaha DME80-es
protocol audio - Ethersound
I control gain remote ;);
