Firstly, a very, very, very Happy New Year to you all!
Secondly, I recently downloaded both the VST3 versions of SAC and SAW and tested each of the applications with a variety of VST3 plug-ins - 50 in total!
I implemented, the procedures as noted in both the SAC and SAW User Manuals for creating "ini" files - and all 50 plug-in worked as expected!
Thus, from my perspective, I was able to treat VST3 plug-ins in the same, identical manner, as VST2 plug-ins!
For this test, I implemented the default plug-in paths:
For SAC:
Path: C:\SAC64Demo\VST_PlugIns
ini file: C:\SAC64Demo\VST_PlugIns\name.dll
For SAW:
Path: C:\SAWStudio64Demo\VST_PlugIns
ini file: C:\SAWStudio64Demo\VST_PlugIns\name.dll
Note: For my setups, I usually go one step further by creating "plug-in type" folders, for example - employing SAC as an example here:
1) C:\SAC64Demo\VST_PlugIns\AmpSim\name.dll
2) C:\SAC64Demo\VST_PlugIns\Reverbs\name1.dll
3) C:\SAC64Demo\VST_PlugIns\Reverbs\name2.dll
4) C:\SAC64Demo\VST_PlugIns\EQs\name.dll
5) ...and so on...
As can be observed from the above examples, I place ALL of my reverb plug-in in the same folder- creating ini files that point to that location.
The only plug-in that I did NOT test were the Waves plug-ins - but as Bob has already provided that information for you, it did not really make any sense to re-invent the wheel.
As always...I do hope that some will find this information of some practicable use?
Thank you for your time...appreciated!
VST3 and "ini" files
Re: VST3 and "ini" files
Since when have we had VST3 support in SAC?
On the other hand, does this solve the problems with the Juce Plugins or does that problem persist?
My Setup SAC:
interface - digigramLX646
preamps - Yamaha Ad8hr
Outs - Yamaha DME80-es
protocol audio - Ethersound
I control gain remote
Bob announced the availability of SAC 64 v2 with VST3 support a couple of days ago.
https://www.sawstudiouser.com/forums/sh ... 2-Released
Thanks for the information. I'm eager to update my Sac64 to see how all the new features work.cgrafx wrote:Bob announced the availability of SAC 64 v2 with VST3 support a couple of days ago.
My Setup SAC:
Ruben,
Sadly, "NO"...these updates do not fix the JUCE issues!
JUCE is a "platform" or a "framework". Thus s the framework has issues - everything else is "downstream".
VST2/3, on the other hand, are what I tend to refer to as "protocols", such as "TCP/IP" and so on.
@Bob: Thanks for the new release.
Do you suggest switching to VST3 even for plugins also available as VST2?
I still believe VST2 is better performance... but you would have to test between the two for your particular system.
Tomy,
Personally, I see not truly recognizable differences and/or advantages between VST2 and VST3!
