Host without screen.
Ruben VS
Post by Ruben VS »
Does anyone use the SAC Host without a screen?
I'm thinking of leaving the host, which is a rack-mounted PC, on the stage and working with Sac64_v2 remote. But I'd rather not have to carry a screen for this.
Is it possible to configure the Host so that pressing the PC's power button will directly activate SAC?
My Setup SAC:
interface - digigramLX646
preamps - Yamaha Ad8hr
Outs - Yamaha DME80-es
protocol audio - Ethersound
I control gain remote ;);
TomyN
Been thanked: 2 times
Re: Host without screen.
Post by TomyN »
Yes. You can go to the task planer and create task and define when it shout start.
Make sure that your system will default to a screen resolution large enough for SAC, because SAC refuses to start when the screen size is too small.
These users thanked the author TomyN for the post:
CharlieCo
andrew b
Post by andrew b »
AutoHotkey\UX\AutoHotkeyUX.exe
