Powershell script to create vst3 ini files
GUE
Post by GUE »
if you have a lot of plugins this will help you
you can call this function in an powershell window [run powershell.exe]
if your VST3 Pluhins are in the Standard folder (C:\Program Files\Common Files\VST3)
with following syntax
.\AddVST3.ps1 -VST_Plugins c:\tmpvst
c:tmpvst is an example u can Also Use (c:\Sawstudio64\VST_Plugins) or the path to your VST_Plugins directory
or use al parameters in the script
.\AddVST3.ps1 -VST_Plugins path_to_your_VST_Plugins_Folder -VST3Directory Path_to_your_vst3_folder
put the code in a file named AddVST3.ps1
Code: Select all
param(
    [string]$VST3Directory = "C:\Program Files\Common Files\VST3",
    [string]$VST_Plugins
# targetdir check if exists and create it
if (-not (Test-Path $VST_Plugins)) {
    New-Item -ItemType Directory -Path $VST_Plugins | Out-Null
# find  .vst3 files recursively
$files = Get-ChildItem -Path $VST3Directory -Filter *.vst3 -Recurse -File
foreach ($file in $files) {
    # create ini File
    $iniName = [System.IO.Path]::GetFileNameWithoutExtension($file.Name) + ".ini"
    $iniPath = Join-Path $VST_Plugins $iniName
    # content: Full Path
    $content = $file.FullName
    # write in US-ASCII
    Set-Content -Path $iniPath -Value $content -Encoding Ascii
hope this helps
cu GUE ;)
Carl G.
Has thanked: 1 time
Been thanked: 5 times
Re: Powershell script to create vst3 ini files
Post by Carl G. »
Where would I put this file to run it? In the default SAWStudio or SAC VST directory?
(maybe if I have to ask, I shouldn't run it.... but I'm willing to try)
Guest
Post by Guest »
You can run the script from anywhere, even on the Desktop.
you specify the paths witch the parameters.
So step1 is to create an empty File named AddVST3.ps1
Step 2 put the code into the file
Step 3 open Powershell and navigate to the directory where the file exists
step 4 run the command in Powershell
for Example with all setups in standardmode Sawstudio is in c:\sawstudio64 run following command
Code: Select all
.\AddVST3.ps1 -VST_Plugins c:\Sawstudio64\VST_PlugIns -VST3Directory C:\Program Files\Common Files\VST3
If You encounter an Errormessage regarding Executionpolicy you can check your current executionpolicy with
the command:
Code: Select all
Get-ExecutionPolicy
it should return restricted, remotesigned or others
in this case you have to enter following command:
Code: Select all
Set-ExecutionPolicy -ExecutionPolicy RemoteSigned
then run the script again
after this dont forget to reset your executionpolicy back to original.
mostly "Restricted"
Code: Select all
Set-ExecutionPolicy -ExecutionPolicy Restricted
hope this is clear for you
cu
GUE
Post by GUE »
Sorry forgot to mention:
you have to save the file with the code in it.
cu
gue
