wiindows 7 and windows 10 optimized setup for SAW
Juan V
Post by Juan V »
hi,
Can somebody point me to the recommended optimized setup to run SAW in wiindows 7 and windows 10 ?
thanks
Juan Vergara
jmh
Been thanked: 6 times
Re: wiindows 7 and windows 10 optimized setup for SAW
Post by jmh »
Consider looking for a reputable de-bloating script to get rid of unneeded junk for your version of windows. There are a bunch on github. The SAWStudio manual has a list of recommended adjustments.
Been thanked: 11 times
There is a script by Chris Titus... you can download an offline version and run that and use the standard debloat tweak items... that can help a lot.
60216
Post by 60216 »
Thanks for the replies.
I will check those
