Carl - the only drawback with Lynx is that, AFAIK, only one card can be installed in a m/c. whereas I know from experience 2 RME's will play together.
cheers
mako
What are people using to get 40 i/o
Naturally Digital
Re: What are people using to get 40 i/o
In fact, the specs say you can run up to 8 cards in a PC and 4 in a Mac. I'm not aware of any other manufacturers that claim you can run 8 of their cards in a system. Having said that, I've only ever run one of the LynxOnes (I still use it) myself.mako wrote:Carl - the only drawback with Lynx is that, AFAIK, only one card can be installed in a m/c.
Somewhere - I thought I saw the limit was 4 (on their site)..David Vanderploeg wrote:In fact, the specs say you can run up to 8 cards in a PC and 4 in a Mac. I'm not aware of any other manufacturers that claim you can run 8 of their cards in a system. Having said that, I've only ever run one of the LynxOnes (I still use it) myself.
since ADAT protocol has its limits (channels vs sampling rates)
Doing the Aurora 8 or 16 is a great option for those that don't mind paying the money. Otherwise, RME dealers are now pushing their MADI systems for channel counts over 24 (12 stereo in/outs)
Harold Thompson
I have a gig on Labor Day weekend that calls for 40 inputs. I'm sure that I will have to feed a rough mix back to the video truck for reference audio. What I have is a laptop with an RME Carbus and a Digiface box. If I got another RME Cardbus + Digiface setup for another laptop and wordclocked them together that would give me enough inputs. My plan is to use SAC on both laptops and feed a submix from on mixer to another to get the monitoring together. I think that should work OK. My question is regarding the recording setup. Can I use the TCP/IP link to just link the SAWStudio master and slave apps on the 2 computers and not the SAC apps while using the SAC-SAWStudio hooks on each computer?
Harold Thompson
Blackwater Recording, Inc.
Harold Thompson
Hi Harold - the SAC-SAWStudio hooks haven't arrived yet - hopefully soon.
The linking 2 m/c's via TCP/IP is something I'm sure (from memory) Bob and others have done in the past.
Try TCP/IP search in SS forum.
Good luck
mako
Good luck
mako
Denis Hillman
Queensland
Australia
Queensland
Australia
Harold Thompson
I know that the link between 2 laptops running SAW Studio can be done (I have used it many times). My question is can it be done with SS inside of SAC?
If you assign different port numbers to SAW and SAC, then you can remote on the same network and they should stay separate.
I will check into it as I get deeper into finishing the SAC remote code.
Harold Thompson
Thanks Bob. In this instance I won't need to link the 2 consoles together, only the 2 SS apps. So it seem that it should work OK.
