SAW Hooks
Been thanked: 10 times
Re: SAW Hooks
At the moment the hooks have not been written in to Basic.... they are completely different source codes and will require me to manually insert all the hooks from the Lite/Full source... lots and lots of code and variable additions... lots more debug time... not sure what I will do there...
Basic as an introductory product to Lite and Full may remain without that feature... we'll see.
mOjO Fet
Re: SAW Hooks
Post by mOjO Fet »
How long is the pre-release sale promotion going to last?
I would love to jump on board. Also now after so many people seem to be really exited about SAC. The possibilities seem fascinating!
On the other hand as a Basic user without the integration of SAC I am hesitating....
I think Basic and SAC with the hooks would be a very powerful combination.....
Michael
Re: SAW Hooks
The Pre-Release will probably hold till mid or end of July... I am behind schedule... I was hoping to have everything finished by now... mid-June... but probably another month.
Ollie
Re: SAW Hooks
Post by Ollie »
RME Digiface
Ada 80000
Desktop system
I was goofing with this a bit today. I set my inputs in SAC to mono inputs. Made a template and started to go live. Then I opened up SawStudio, got it to hook to SAC by Activating SAC Link and then getting the Sac Link Option you wantImport Mix Data from Sac . Everything is working fine. Data being recorded to SawStudio. Great.
Now I go into SawStudio and choose Export Mix Data to Sac. By necessity that has to change in Sac where the data is coming from so you can hear the tracks. Say I want to get back into my live session ASAP, Bob what do you recommend is the quickest way to do that and return my inputs for live PA?
Thanks.
Re: SAW Hooks
What you will want to do now is keep the live session setup and run one more SAC input from the SS Output Track 1... that will be your playback... exactly as we have all done it since the beginning with a physical console.
The export is for a one to one mixdown arrangement... not for a tracking arrangement... unless you want that much onitor control while tracking vocals or something.
I am also working on a live Tape Style switching playback feature that will do what you want while the Record Meters are present... but it is not ready yet.
Or... if you want to switch between the two completely different setups... just create a scene for each setup and then just switch scenes to get back to your recording setup.
Ollie
Re: SAW Hooks
Post by Ollie »
Got it. Thanks.
