I feel like the newbie, but one more question
Tom B
Post by Tom B »
Been using VCA for a while now.. I know there's none on SAC, so here's what i've done but need help with
assigned all drums to output 1 and configured for adat out 1+2
assigned all guitars to output 2 and configured for adat out 1+2
assigned all keys to output 3 and configured for adat out 1+2
assigned all vocals to output 4 and configured for adat out 1+2
assigned all effects to output 5 and configured for adat out 1+2
what I want is a "master" volume that once those 5 are set for the mix that "output 6" could control ALL volume.. is that possible?
I know.. I sound like a beginner lol
cgrafx
Been thanked: 7 times
Re: I feel like the newbie, but one more question
Post by cgrafx »
Tom B wrote:Been using VCA for a while now.. I know there's none on SAC, so here's what i've done but need help with
Use the subgroups.. 9-24 and then assign the subgroups to Channel 1 output
Drums -> 9
Guitars -> 10
Keys -> 11
Vocals -> 12
Effects can go to a subgroup or directly to output 1 or just to the vocal subgroup if you just want to process vocals.
Subgroups 9-24 can also be configured to act like VCAs
Tom B
Post by Tom B »
cgrafx wrote:Use the subgroups.. 9-24 and then assign the subgroups to Channel 1 output
Drums -> 9
Guitars -> 10
Keys -> 11
Vocals -> 12
you sir are the BOMB
TomyN
Been thanked: 2 times
Post by TomyN »
Well, you can use any of the output faders 9 to 24 as a kind of VCA. Despite to a default VCA they will move the fader of the inputs assigned to it visually.
