Hi, I have the following situation when I solo a track that has music say from a computer using TRS jacks. The music suddenly jumps
really loud as if the volume was increased 5x time or so. I don't know if any one has experience such. I am using an RME Digital USB
with an AD8200. I will need to test if this is the same for Mics. Please any one has an idea let me know. Maybe I have a wrong set up.
Thanks in advance and have a blessed day.
Solo button makes audio extremely Loud
Re: Solo button makes audio extremely Loud
Try the different pre/pst solo options in the Mixer Menu/Solo Mode menu.
Also... right-clicking the solo button at the top of the screen lets you adjust the master solo volume.
Check the routing of both PFL/Solo busses. I assume that you route the pfl signal to your main output.
Tomy,
I do believe that this result is to be expected. So, here is what I always do,
For Mixer Menu, Solo Mode, select: Solo-In Place - Mutes Other Channels
- This is Option 12
Hi, every one I forgot to say "Thank you" for your responses.It really help me. SAC & SAW Rock. I wish I could code in Assembler language like Bob. Trying in my own corner.
Have blessed day.
Have blessed day.
