Hi,
After moving to SAC64, I'm looking for a simple VST recorder (like TapeIt) as 64Bit VST2 plugin.
Tomy
TapeIt 64Bit
TapeIt 64Bit
Re: TapeIt 64Bit
SAWStudio using the SAC Link would be the best choice... you can record full multitrack as well as up to 8 stereo mix busses assigned from any SAC output.
Re: TapeIt 64Bit
Bob's response reminds me of the song "Blowin' in the Wind", wherein, I updated the chorus to "When we we ever learn? When will we ever learn?"
Re: TapeIt 64Bit
Well, doing a short serarch I came across many 'Tape plugins'.
But I do not need more than stereo, no tape-saturation, no wow and flutter, no tape-aging and no incorrect azimuth simulation. Even no playback needed.
Just a simple plugin that copies the audio data to a file, like tape-it does for 32Bit.
Re: TapeIt 64Bit
I understand it may seem like overkill, but SAW Studio will do exactly what you're asking for. It just also gives you the flexibility to do more should the need arise.TomyN wrote:Well, doing a short serarch I came across many 'Tape plugins'.
You don't have to record every channel. You can record a single stereo audio file from any SAC output channel.
Re: TapeIt 64Bit
Haven't tried it in sac, but Melda Production's free MRecorder might be worth a try
operationwhat
- Member
Re: TapeIt 64Bit
Here's an alternative...
1. install Odeus Asio Link Pro drivers
2. link your cards drivers
3. set SAC to one of the cores of your processor
4. open any DAW and record what is coming into the card or that goes out...
5. you can loop the signals and re-patch them from out to in and vise versa.....
https://give.academy/downloads/2018/03/ ... IOLinkPro/
Emjoy!
Emjoy!
Re: TapeIt 64Bit
Well... I could also use Dante Virtual Soundcard in a DAW and patch the output of SAC. But I just want a simple plug in solution, so I'll check the melda stuff.
