Been a while and I thought I would try some things with SAC. I have Dante Via installed and have select the ASIO device for it, it shows the 16x16 inputs and outputs, but when I try and go live it gives me "Trouble opening In device Make certain device is capable of current parameters" etc, etc.
Any ideas on what is causing this?
I have screen shots of everything but can't seem to get things to upload here.
Dante Via?
Wurst Werner
Re: Dante Via?
Same with Waves QRec (similar to a DANTE VSC), SAC sees it but the Audio Engine doesn't start.
If have a couple of SoundGrid stageboxen that are remoteable with QRec. Works with any other daw. Seems that the ASIO implementation in SAC does not work with it.
https://www.waves.com/mixers-racks/soundgrid-qrec
[CENTER]
[/CENTER]
[/CENTER]
Re: Dante Via?
what buffer settings are you using?Mr Loud wrote:Been a while and I thought I would try some things with SAC. I have Dante Via installed and have select the ASIO device for it, it shows the 16x16 inputs and outputs, but when I try and go live it gives me "Trouble opening In device Make certain device is capable of current parameters" etc, etc.
Re: Dante Via?
It pulled the sample setting form Dante Via 128bit and is set to 4 buffers.cgrafx wrote:what buffer settings are you using?
Re: Dante Via?
Make sure that the mixer settings in SAC (width, samplerate) match the settings of VIA
