sac font
sac font
Hi, is it possible to change the font for fader labels in SAC? The default one doesn't display cyrillic letters correctly.
Re: sac font
Andrew,
Not that I personally know of. This really should be a question for Bob directly.
Both SAC and SAW have a .dll in the root folder that is labelled "font" of some sort. Not sure that this file does exactly.
* I have been able to delete these files and all appears to work as normal.
* At others times during various testing procedures, this is the only file that will not delete, until you log-off/log-on to the system.
Let us know what you find out from Bob.
Re: sac font
he does not want to answer, there is no solution (mr_es335 wrote:Andrew,
Both SAC and SAW have a .dll in the root folder that is labelled "font" of some soft. Not sure that this file does exactly.
operationwhat
- Member
Re: sac font
X32 can write <>. and caracters like that...andrew b wrote:Hi, is it possible to change the font for fader labels in SAC? The default one doesn't display cyrillic letters correctly.
so what?!
K***1086;***1112;***1080; ***1115;***1077; ***1090;***1080; ***1115;***1080;***1088;***1080;***1083;***1080;***1094;***1072; ***1091; ***1057;***1045;***1050;-***1091;?
nether this forum can show cirilyc fonts see, but it works
