SAC Control
SAC Control
Hello everyone. I have been having a great time working with SAC but I have one little challenge, its very little but I'll state it. Working with SAC I find I from time to time do miss having knobs to control channel strip (Eq and Dynamics), so my question is, is there any control surface for which a template exists in sac that allows control of the channel strip? Thanks in anticipation of your responses.
Re: SAC Control
The older behringer bcf/bcr 2000 work. I believe the newer Behringer X-touch controllers also are useable. I have used a Bcf2000 on occasion, but have not used an x-touch and therefore cannot say for certain.
Re: SAC Control
You could check this out https://www.youtube.com/watch?v=ZJgAs-53U5A I personally find it's much easier just to use the computer keyboard as the the alternatives are just too much mucking around.
Re: SAC Control
Stephen,
Ditto!..Ditto!...Ditto! on what Reujonik stated...
For what it is worth, check this out...seriously: [Click_Me]
Hope this helps?
- Stephen, you really...I mean "really"...need to spend some time reading the user manual and seeing what is available for keyboard usage.
- Also, please give yourself time in gettng accustomed to such usages...usually 90 days will suffice. Believe me, you will NOT regret this time spent!!
- For more info: [Click_Me]
Hope this helps?
Re: SAC Control
The Mackie Control units work well with the readout displays and controls for all the mixer parameters.
Re: SAC Control
The MackieMcu templates work fine with the xTouch, tested with 8 channels and 16 channels.
Re: SAC Control
Thanks everyone for the responses, you've all been very helpful. @Dell I am currently going through the manual to het better at working with the keyboard, its the least expensive way to go and I saw some where that its how Bob works, if it works fine for him, I'll put it in some more time to it. @Bob a curious question, does that mean that the Mackie C4 and C4 pro will work fine for channel strip? Thanks all, this has been a fun ride and I'm grateful this support group exists.
Re: SAC Control
The Mackie MCU Control Universal is the one.... there are a few on Reverb.com for a few hundred bucks at the time of this message.
