Some time ago, someone on the forum was "BnC'ing" about "404 errors", and I felt is was necessary to explain the cause for this anomaly.
Two things were the subsequent cause for this anomaly...
1) A change in the hosting provider
2) A change in the hosting server
Though the first was not necessarily the cause for this anomaly, the second cause most definitely was!
Though I am not at all certain what OS was being employed for the initial hosting provider, I do know that the second is using Linux - which is, interestingly, "case sensitive!!"
This meant an update to all of the paths in any of the postings that I had previously made...which, in short is "pretty darn near impossible!!"
What this means to you then, is that if you happen to come across a "404 Error" that you send me an email noting the posting that is in error and I will update that posting accordingly.
Sound good? Great!
PS: My apologies for any inconveniences that has resulted in the above changes.
An important note! "404 Not Found" Errors
