Due to a change in software, I had to make the move to WIN10.
With thanks to cgrafx for his insight into LTSC, I have been attempting a clean-install of WIN10 on my production system. In short, I very much dislike Windows 10!
It appears that during each-and-every install that something else crops-up that requires attention. One thing for sure - disable updates...immediately.
* The initial install image size was 5,188,820
* After the so-called "required" updates, the subsequent image size was 10,026,976...an increase of 4,838,156..and for WHAT! Fluff!!
* Also, along with O&O ShutUp10, I have disabled no less than 326 "things".
7 installs later and I am finally getting to the point where I would be with WIN7.
All that I can say, is that I sure hope that all of this effort is worth it!!
SOT: WIN10 LTSC
John Ludlow
- Been thanked: 1 time
Re: SOT: WIN10 LTSC
I had not heard of ShutUp10. It looks very interesting. And, I see that it has an export settings option. If your settings work out after careful testing - maybe you could export your ShutUp10 settings and make the file available for others? On the other hand, if Win10 is still lacking, consider Project Lasso (another Phillip contribution).
https://bitsum.com/
If you haven't worked with 64-bit headroom, you may find that you like that a lot. Plenty of RAM address space for VSTs.
And, yes - it's nuts how much you have to go through to make Win10 play great with SAC/SAW. But it is doable.
https://bitsum.com/
Re: SOT: WIN10 LTSC
John,
You stated..."...If your settings work out after careful testing - maybe you could export your ShutUp10 settings and make the file available for others?..." ...Okay, John...here 'ya go [Click_Me]
John Ludlow
Re: SOT: WIN10 LTSC
John,
Three very important "things"...1) Backup, 2) Disk-image, and 3) Repeat...
Update!
Along with ShutUp10, Winaero Tweaker is also a "must have". This is a "portable app" and it is available for free.
* I have provided my version here - which includes the accompanying .ini file of tweaks that I employ. Just unzip and launch...
* The most recent update is not required as this update is only pertinent to WIN11...so ignore...
Update!
Re: SOT: WIN10 LTSC
Well, my installation of Windows 10 LTSC [1809] has finally been completed...at least on the"Test System"...which I refer to as the "Development System".
I was having a number of major issues, but eventually discovered that these issues were due to a faulty disk-imaging flash drive.
I will now be porting over the installation to the actual "Deployment System".
Here is a screen capture of the Task Manager...
I will keep interested parties updated as to my progress....hopefully not regress...
