I hope that the day finds you well!
Due to the need to "down-size" my "Live Rig" set-up, I obtained a Behringer U-PHORIA UMC1820 USB interface.
I require some clarification on "MONITORING and MAIN OUT 1-2" of this unit and am wondering if anyone can be of assistance to me here?
Please peruse the following: [Click_Me]
Any assistance in this matter would be greatly appreciated!
Thank you for your time....appreciated!
OT: Behringer U-PHORIA UMC1820
Re: OT: Behringer U-PHORIA UMC1820
If I understand things correctly, as I am not monitoring, only controlling the main output, I would turn the PB 1-2 fully clock-wise...and then, simply, "leave it at that!"
Would this configuration be correct?
Correctmr_es335 wrote:Hello,
I've the 204 HD, the only negative point for me is the headphone output.
ivanoff,
Great to hear from you!!! And I hope that you are doing well?
You stated, "I've the 204 HD, the only negative point for me is the headphone output." I have the 202HD as well. May I ask what issue you are having with the headphone output?
PS: Thanks for the clarification...appreciated!!
After reading a rather negative review on the output headset of my 204 HD I made a comparison with that of my Echo Layla G and actually the output headset of the Berhinger has a loss in the bottom and maybe less accurate and harsh. Nothing dramatic but as I mix with headphones for neighborhood reasons I am more sensitive to this small defect. Good preamp, no noise. The power connection is very sensitive, sometimes the sound stops if I move it a little Maybe just mine or a 204 HD issue..mr_es335 wrote:ivanoff,
But for the price it's a good deal
