This Month are you in?
Microstudio
Post by Microstudio »
Ok, let's record, mix, and master a song this month, using SawStudio, and share it. I will!
jmh
Been thanked: 5 times
Re: This Month are you in?
Post by jmh »
Hmm, I've got one I'm writing (unusually fast) that is coming together nicely. It's going to be a simple mix (which are the only type I can get done before I burn out and screw it up) I'll try to do that one, so yeah, I'm in - although experience has shown me that I may have to get one of you guys master it.
Todd R
Has thanked: 26 times
Post by Todd R »
well, it's time to final mix my film...which is happening in SAWStudio
I typically don't make much music in SS
sadly, I have recently gone over to the dark side for music production
I had been using Reason...but have moved over to the dreaded CB; which has been a good experience so far; very quick workflow
I do have new guitar song that has just sprouted up after firing up some old gear...maybe I'll do that...doubt I can find the time this month with winter just around the corner
when my film is done, I will share!
