Programatically Configure F-Key Views
I have discovered a way-and-means of being able to programmatically configure F-Key views!
Hhhhmmmm....
Re: Programatically Configure F-Key Views
As I noted, it is now entirely possible for you to configure all of your F-Keys programmatically!!! Here is the completed script:
; PositioningViewsF12
; Status: Working
; Date: 7:47 AM 11/1/2025
PositioningViews()
Func PositioningViews()
ActivateMain()
ZMixer()
Scenes()
FXChoices()
FXPrePatches()
FMixer()
StoreView()
SaveView()
EndFunc ;==>PositioningViews
Func ActivateMain()
Local $hSAC_MAIN = WinActivate("[CLASS:SAC_MAIN]")
EndFunc ;==>ActivateMain
Func ZMixer()
Local $iTimeOut = 250
Local $hSAC_ZOOMMIXER = "[CLASS:SAC_ZOOMMIXER]"
; (1) Display the view
Send("{ALTDOWN}")
Send("{ALTUP}")
Send("V")
Send("Z")
; (2) Position the view
WinMove($hSAC_ZOOMMIXER, "", 5, 80, 103, 970)
EndFunc ;==>ZMixer
Func Scenes()
Local $iTimeOut = 100
Local $hSAC_SCENES = "[CLASS:SAC_SCENES]"
Send("{ALTDOWN}")
Send("{ALTUP}")
Send("V")
Send("1")
WinMove($hSAC_SCENES, "", 113, 80, 356, 453)
EndFunc ;==>Scenes
Func FXChoices()
Local $hSAC_FXCHOICES = "[CLASS:SAC_FXCHOICES]"
Send("{ALTDOWN}")
Send("{ALTUP}")
Send("V")
Send("C")
WinMove($hSAC_FXCHOICES, "", 113, 535, 356, 240)
EndFunc ;==>FXChoices
Func FXPrePatches()
Local $hSAC_FXPREPATCHES = "[CLASS:SAC_FXPREPATCHES]"
Send("{ALTDOWN}")
Send("{ALTUP}")
Send("V")
Send("E")
WinMove($hSAC_FXPREPATCHES, "", 113, 780, 356, 150)
EndFunc ;==>FXPrePatches
Func FMixer()
Local $hSAC_FULLMIXER = "[CLASS:SAC_FULLMIXER]"
Send("{ALTDOWN}")
Send("{ALTUP}")
Send("V")
Send("F")
WinMove($hSAC_FULLMIXER, "", 474, 80, 240, 648)
EndFunc ;==>FMixer
Func StoreView()
Sleep(500)
Send("{LSHIFT}+{F12}")
Send("{ENTER}")
EndFunc ;==>FMixer
Func SaveView()
Sleep(500)
Send("{ALTDOWN}")
Send("{ALTUP}")
Send("F+F")
Send("{UP}+{UP}")
Send("{ENTER}+{ENTER}")
EndFunc ;==>FMixer
If you are at all interested, email me, and I can send you a compiled version for your own perusal.
At present, I am compiling the data for determining precise placement of all of the various views based on default sizings [x [TOP], y [LEFT], h [HEIGHT], w [WIDTH].
Once such data has been determined and then provided, I can then place these views in the workspace at the given co-ordinates.
Interestingly, the script took me about 2 hours to produce, but now that the script is completed, the above
script created the F12 view in under 2 seconds. Thus, 12 views would take a total of 24-30 seconds to complete!
And, by-the-way, we are referring to 0.5 pixel accuracy here!!
Update!!
Completing the "math", I was able to create 9 views [F1] to [F6] , [F10] to [F12] - all without having to launch SAC - with the entire layout being completed on paper!!
* PS: I do hope that "ya'all" realize that this script would also work with SAW!!!
Dave Labrecque
Post by Dave Labrecque »
Sorry to be so dense, Dell. What does programmatically mean in this context? What have you achieved here? How has my SAW world been enhanced? :confused:
Dave,
You stated, "Sorry to be so dense, Dell. What does programmatically mean...?"
It is not that you are "dense" in any manner whatsoever, Dave. It is simply the fact that I really should have been more explicit!
Firstly, "programmatically" - from the term "programmatic" - simply means, "pertaining to, or of the nature of, a program".
When I am configuring SAC [...or SAW for that matter...], I select-and-drag, the various "views" to their respective locations - indeed as we ALL have done!!
Depending on the monitor's "Display Resolution" - this resolution defines the width and the height [...in pixel, or px...] of what we are able to view on that display resolution at any particular time. The two most common display resolutions at present are 1920 x 1080 and 2560 x 1600. We will focus on the display resolution of 1920 x 1080 for this response - as the display resolution of 1920 x 1080 is the more common display resolution at present.
Employing a display resolution of 1920 x 1080, I
Warren
Post by Warren »
mr_es335 wrote:Good day,
; Status: Working
PositioningViews()
ActivateMain()
ZMixer()
Scenes()
FXChoices()
FXPrePatches()
FMixer()
StoreView()
SaveView()
Func ActivateMain()
Func ZMixer()
Send("{ALTDOWN}")
Send("{ALTUP}")
Send("V")
Send("Z")
EndFunc ;==>ZMixer
Func Scenes()
Send("{ALTDOWN}")
Send("{ALTUP}")
Send("V")
Send("1")
EndFunc ;==>Scenes
Func FXChoices()
Send("{ALTDOWN}")
Send("{ALTUP}")
Send("V")
Send("C")
Func FXPrePatches()
Send("{ALTDOWN}")
Send("{ALTUP}")
Send("V")
Send("E")
Func FMixer()
Send("{ALTDOWN}")
Send("{ALTUP}")
Send("V")
Send("F")
EndFunc ;==>FMixer
Func StoreView()
Sleep(500)
Send("{ENTER}")
EndFunc ;==>FMixer
Func SaveView()
Sleep(500)
Send("{ALTDOWN}")
Send("{ALTUP}")
Send("F+F")
Send("{UP}+{UP}")
EndFunc ;==>FMixer
Update!!
Are you speaking via Windows Registry?
Yes I would be interested in the creation process.
Thanks Dell
Warren
Warren @ The Masters Tracks ;)
Sent PM!!
Man! This script is working out wonderfully!! Have a look-see...[Click_Me]
For your interest, the entire SAW|SAC Installation|Configuration routine that I employ, consists of a total of 8 procedures.
The most extensive of these procedures is Procedure 7 - which manually takes approximately 4 hours to complete successfully!
After spending a similar period of time producing the "automation script" for Procedure 7, I am now able to complete the very same procedure in under 50 seconds!!
I do believe that it is important to note that much of this script is "portable" - that is, much of the script can be deployed in "other" scripts - making it so that I do not have to "re-invent the wheel"...so-to-speak!
I have one more procedure to complete - and then I will see how long it takes to complete all 8 procedures - which I have never actually determined, but this process involved a period of a full day...maybe even 2!
