Video Bug?
Dingo
Video Bug?
Post by Dingo »
Every so often when I move a plugin window or the MT window, I get what looks like repeating copies of the window that don't go away until I either restart SAW or the computer. Anyone have any info on this? Like how to get rid of it?
Thanks,
Dave
Carey Langille
Re: Video Bug?
Post by Carey Langille »
What is your Video card/Computer setup??
Carey A. Langille
Producer/Engineer
Ocean Sound Productions
www.oceansoundstudio.com
Creativity at the Speed of Sound
Been thanked: 9 times
Re: Video Bug?
Dave,
Check to see if you have the 'Show Window Contents While Dragging' Windows option ON in the Windows effects options.
Try turning it off and see if that helps.
This is found in different places depending on which Windows OS you are using.
Win 2K... right-click on the desktop... choose properties and then select the Effects Tab.
Win XP... right-click on the desktop... choose properties and then select the Appearance Tab and then the Effects button.
Dingo
Re: Video Bug?
Post by Dingo »
Thanks Bob. That seems to have worked. Love SAW by the way.
