Scenes
Craig Allen
Scenes
Do they not (currently) include FX bypass switches? It doesn't appear to be working here on DX plugins.
-Craig
Re: Scenes
You are correct... only the console channel FX Bypasses are working in the Scenes currently... I have much work to do on the rest of the FX stuff... gets much more involved... but I have some concepts in the background ready for experimentation soon.
I am also working on plugin settings saving in the Scenes... therefore you will have complete control of your DX and VST plugs... hopefully.
Craig Allen
Re: Scenes
Once again, very cool! I'd love to have that kind of control!Bob L wrote:I am also working on plugin settings saving in the Scenes... therefore you will have complete control of your DX and VST plugs... hopefully.
-Craig
