Feature that may be helpful
Is there a way to copy all Dynamics settings from the house mixer into a monitor mixer? I could see that this would be advantageous. It may or may not be as helpful with EQ, but with compression and getting things to sit well, this could be helpful in monitors as well.
Re: Feature that may be helpful
I have code in the works for maybe the next update or the one after that will allow all kinds of copies from one mixer to the next... right now, you could duplicate channels by simply selecting the channels you want to copy and using the channel save/recall options (Alt-Right-Click any mixer view)... save to file... it will save all selected channels... then change to the monitor console and recall from file... it will duplicate from those template files.
I will have to try that again. I did try that and it did not work, but perhaps I went about it the wrong way.
*** This does not appear to be working for me *** Perhaps I have the wrong procedure.
I am doing the following
1. Store all from Channel to file (after selecting the channels I wanted)
2. Recall all from the file to Channel (after selecting the channels I wanted)
Bud Johnson
Just a thought, are the channels named?Ollie wrote:I will have to try that again. I did try that and it did not work, but perhaps I went about it the wrong way.
When saving, is it creating as many files as you have channels selected?
good find
fvf
fvf
Frank V. Farrell
TD / Kenny Rogers Productions
W0FVF
ETTI,LLC
http://www.CIALLC.com
Knowledge is knowing a tomato is a fruit.
Wisdom is not putting it in a fruit salad.
W0FVF
ETTI,LLC
