SAC / SAW FX
Craig Allen
SAC / SAW FX
Post by Craig Allen »
I just purchased and installed the Anwida Equo pack from the group buy, but I did it in SAW. I went to install it again for SAC and it won't install twice. Is there anyway SAC could read what FX are installed in SAW and have access to those?
-Craig
Been thanked: 9 times
Re: SAC / SAW FX
It most likely will not install into SAC anyway, since their install program does not recognize the SAC FX ini file.
You can copy the dlls into the SAC Native_Plugins folder and manually add the entries into the SAC_FX_Native.ini file.
Mountain Media
Re: SAC / SAW FX
Post by Mountain Media »
Bob L wrote:It most likely will not install into SAC anyway, since their install program does not recognize the SAC FX ini file.
This way works fine!
John
Mountain Media, Inc.
IraSeigel
Re: SAC / SAW FX
Post by IraSeigel »
Craig,
I did exactly as described above with the Equo Bundle, and it worked as you'd expect. And very low CPU load added with the comp and parametric across the main output bus.
BTW, I believe tomorrow (June 15) is the last day for the Anwida group buy.
Ira
