Just checking in.
Thanks Bob for SAC
Now....
I noticed after linking with SAC 1.0, SSL has 4 channels grayed out.
42, 69, 71 & 72
Shut-down fix with SSL and SAC?
Hap
Anything to Report - 1.0
- HapHazzard
- Been thanked: 1 time
- Contact:
Re: Anything to Report - 1.0
The SACLink code has been modified and you will need to use the new 4.3 SAWStudio and Lite update to work with SAC 1.0... I am compiling now and will have it ready in a few hours.
- HapHazzard
- Contact:
Great, Thanks for the update.Bob L wrote:The SACLink code has been modified and you will need to use the new 4.3 SAWStudio and Lite update to work with SAC 1.0... I am compiling now and will have it ready in a few hours.
Hap
- HapHazzard
- Contact:
SAC 1.0 and SSL 4.3
All is well and everything is behaving nicely.
No grayed out channels and no closing crashes.
Thanks
Hap
Thanks
Hap
