I have tried to patch Studio Levelizer as well as other effects at this point and it is bypassing, Post fader is fine. I have tryed this on the monitors and seem to have the same problem.
I just tried the echo/delay and eq in the output pre patch and they work fine...
Don't forget... if you try the Levelizer in SAC and you have the Peak Limit Normalize engaged, it will be bypassed because it will activate buffer size changes.
Instead, use it in compressor only mode with infinite ratio.
