Dear Guys,
i am so happy with SAC for many years with our IEM mixing console… But everything is evolving…so, i want to control scenes via Sawstudio with control track or with showcontrol- i don’t know, wich is more appropriate- because we use Ableton with multitracks from an external laptop from Worship Director/pianist….so i want midi trigger from Ableton to Saw/Sac….given scene for given song….fx plugin updating from external midi devices
directly to Sac, would be best….but i know, it is impossible…
Thanks for any ideas!
Balint
Scene controlling via Sawstudio- SacLink from external Midi devices
virtualmixingconsole
- Member
Re: Scene controlling via Sawstudio- SacLink from external Midi devices
You can setup cue points down the timeline and jump to them with midi triggers from any external midi source... then set SAWStudio to switch scenes from those triggers... the scenes can then be used to switch FX settings or adjust faders and pans and eqs etc.
- Member
Ok,
i can set cue points on control track and switching via Saclink works, but midi trigger and note number is gray, i can’t edit this parameters…when i set in midi devices option a hardware midi devices, is also gray…tested on Sawstudio64Demo….i’m missing something?
Thanks,
Balint
Thanks,
Balint
Balint,
I am hopeing that we can talk on the phone sometime?
i have some very interesting ways-and-means of using Show Control...and would love to discuss this with you.
