SOT: Active-Inactive Title Bar Colours
I hope that the day finds you all very well!
For those of you [...and even myself...at times...] are discovering some of the annoying idiosyncrasies of WIN10, I may have at least one possible resolve for those that are interested...
Consider the following:
Observations
As we are already aware, the active|inactive title bars are noted by the colour of the text. Thus, we require no other reminders of what window is currently active...or not.
Thus, if the above DOES indeed annoy you...as it does me, then I have a "fix" for you...indeed if you have not already resolved this for yourself?
So, let me know...
Thank you for your time...appreciated!
Re: SOT: Active-Inactive Title Bar Colours
"Gaaawww-llleeee!" I should have noted the alternative...
Though the colours that I had selected are NOT completely accurate, this "discovery" was initiated during the initial testing phase of this endeavour.
With the shade that I currently employ, the active|inactive colours are non-existent! "Yahoo!"
Carl G.
Post by Carl G. »
mr_es335 wrote:Good day,
Personally, I like Windows 11 choices. The Colours (in my case) are a nice sky blue with yellow type descriptions. Very easy to spot which window in SAWStudio is active.
Carl G.
Voice Talent/Audio Producer
www.creativetrax.com
