Cool New V2 Update (2.4)
Dave Labrecque
Has thanked: 15 times
Been thanked: 15 times
Post by Dave Labrecque »
Hey, Bob. Thanks for this.
Question: will the enhanced Ctrl-Backspace stuff work for both MT and SF View record remotes?
Also: do you have plans to do the same for the Backspace and Shift-Backspace functions? Why did you focus on Ctrl-Backspace? Just the potentially higher stakes?
Been thanked: 9 times
Re: Cool New V2 Update (2.4)
Because that one was causing issues with a particular user's setup.
