I need your help. I've had this experience twice now and I was even thinking of calling Bob to get his advice. I thought I'd bring it up here in case we can help others avoid my nightmare.
Anyway, I know I'm making classic mistakes and I'm also due for a re-read of the recording section in the manual but here's what's happening:
1. Classic mistake #1... Busy session, running late on the setup. I started sawstudio with a blank edl, labelled my tracks (may have gone into record rdy mode to check levels on the meters) and saved the edl to a master project folder, naming it "Setup". I then saved it again with the name of the first song. Each time we moved on to a new song I'd save and close the current edl and open the "Setup" one, save it with the new song name, record and repeat. (all in the same folder)
We got a little past halfway through the session and started to listen to the takes... Unfortunately we seemed to have 4 different edls referencing one set of wav files. Needless to say, we re-recorded the tunes and saved the day but it was embarrasing. Understand that this was a hectic session with busy players on a holiday Monday.
Classic mistake #2: Using un-do in the middle of a recording session. This happened today... I no longer make classic mistake #1 so everything was going smoothly (even comping together a lead vocal on the fly!... quite an accomplishment for me
Anyway, all kidding aside, I could use some help with this. I really need to hone the routine before I embarrass myself any further
Any suggestions?
Thanks.
