F Veiw
HapHazzard
Been thanked: 1 time
Contact:
F Veiw
Post by HapHazzard »
Howdy Bob,
Just wondering if I overlooked a view feature.
Is it possible to open more then one F View.
Defined as:[INDENT]To have more then one F view opened, such as a input view, route view and out view. Right clicking over that view only effects that view. Switching from FOH to any of the Monitors would not effect the overall layout of the present views.
[/INDENT]In this type of viewing one could have the routes and masters opened to view those meters and have instant access to faders (panic leaps).
Just a thought :D
Like you don't have enough on your plate.
Hap
Been thanked: 10 times
Re: F Veiw
Currently, only one F view at a time...
Screen real estate is valuable and scarce... so multiple views just to get to returns and outs is not my favorite concept.
The use of the I, R, and O zones gets you there fast... and the use of the Tab key does also... don't forget the right-click popup jump menu that lets you jump anywahere directly... I believe there are more than enough ways to instantly get to the different console sections as it is now.
